I've been chasing a non-defrost problem around for several weeks; changed the easy stuff (defrost timer, defrost termostat). Seems the likely culprit will be the defrost heater. I'd like to test continuity of this, but I find it impossible to reach both arms into the SxS freezer compartment to unplug the thing. This heater is mounted behind the condenser coils, and all I can forecast is damage to the coils and fins if I have to dismount the assembly. How to get the heater element out? From the back? Anybody know? Thanks for your responses.
Right, Woodchuckie, the assembly is perfectly in full view. There's a little lip around the freezer side panels that restrains the assembly from being pulled forward. With the heater element being behind the evaporator coils, how does a person get it removed? Especially as there's room for only one arm to reach in there? And the heater end plugs are behind the evaporator unit, so they can't be unplugged for a continuity check. I hope I'm describing the situation clearly. Thanks!
