Snake
#1 Posted : Wednesday, July 22, 2009 12:50:33 AM(UTC)
Snake
The gas company came over after i smelt gas again(fixed gas leak in line before) by my stove. This time they said it's coming from in the oven. The faint smell of gas only seems to be when the stove is off. Is this a common problem and if so is there an easy fix? :confused: Thanks !!
Snake
#2 Posted : Wednesday, July 22, 2009 12:50:03 PM(UTC)
You have to check all gas lines and gas connections inside the range with soap bubbles to pinpoint the leak.
