Rfunaro
#1 Posted : Tuesday, July 21, 2009 12:26:58 PM(UTC)
Rfunaro
Amiral Dryer Model ADE7000AYW s/n#15150625GC is dead. I changed the door switch, thermostat control,and the T-stat hi limit control and the unit is still dead! What else could it be? Please help!
Rich
rjfunaro@comcast.net
parts changed:
AP4039476 thermostat control
AP4056436 Stat hi limit control
359484 Door switch
sidfink43
#2 Posted : Wednesday, July 22, 2009 10:22:32 AM(UTC)
sidfink43
Before you get any more new parts, check this part for continuity.
Part number: AP4038936
If it, and all of the electrics check out your problem may be in the gas burner system.
Rfunaro
#3 Posted : Wednesday, July 22, 2009 1:52:13 PM(UTC)
Rfunaro
PArt numbers: AP 4056436 T-Stat Hi Limit
AP 4039476 Thermostat control
Door switch
All of the above parts have been changed win new parts.
Dryer still dead!
Your thoughts ??
sidfink43
#4 Posted : Wednesday, July 22, 2009 3:08:50 PM(UTC)
sidfink43
Your machine has a cycling thermostat which it appears you have not checked.
Rfunaro
#5 Posted : Wednesday, July 22, 2009 5:24:18 PM(UTC)
Rfunaro
Where would I find this cycling theromostat, and what does it look like? I have had the front, top, and back of where the knobs are, and I don't see anything else that even remotely looks like a thermostat?????
sidfink43
#6 Posted : Thursday, July 23, 2009 9:11:30 AM(UTC)
sidfink43
It looks like the one in the picture. It should be on the blower housing. If you do not have one check to make sure you have 120 volts to each side of the connection block (I am assuming this is an electric dryer). If it is gas see the other posts on this Forum about gas coils and dryer not operating.
Guest
#7 Posted : Wednesday, September 29, 2010 8:49:23 PM(UTC)
Guest|2
This is an old post, but, I found it via a web search for the same problem with the same model dryer. For future reference, the problem with this dryer is/was the Thermal Fuse. It is located at the top rear left of the dryer towards the bottom of the heating element (little hard to see and to get to). The part number for this fuse is 53-1096 (or AP4056527), but, the suggested fix is to replace both it and the High-Limit Thermostat (part# 53-0771 or AP4056436 as noted in original post) as its failure to operate properly is what caused the fuse to blow. The High-Limit Thermostat is located just above the heating element and has a large blue sticker on it. Both these parts come in a kit that includes replacement parts for both electric and gas dryers. The part number for the repair kit is LA-1053 and is commonly available on the web for around $25. I found the best bargain on feeBay for about $12.
