Doug Bahniuk
#1 Posted : Monday, July 20, 2009 7:51:37 AM(UTC)
Doug Bahniuk
What's the best way to replace the motor? Remove the front panel?
How do you take it off?
#2 Posted : Monday, July 20, 2009 7:42:15 PM(UTC)
Doug,
The model number you posted does not come up. Verify and repost it.
Doug Bahniuk
#3 Posted : Tuesday, July 21, 2009 5:08:40 AM(UTC)
Doug Bahniuk
its either wed6500sqo or wed6500sq0 (either the last digit is a 0 or an o)
#4 Posted : Tuesday, July 21, 2009 11:53:02 AM(UTC)
Is it an American model?
Doug Bahniuk
#5 Posted : Tuesday, July 21, 2009 12:24:21 PM(UTC)
Doug Bahniuk
yes, purchased in ohio. I copied the model number off the front of the unit. the invoice also has that model listed.
#6 Posted : Tuesday, July 21, 2009 1:26:14 PM(UTC)
Check the name plate on the door frame. This model number does not come up anywhere. It could be "6200" or "6400".
Guest (5)
