ellist
#1 Posted : Saturday, January 5, 2008 1:32:08 PM(UTC)
ellist
large burner will not heat, the element will work on the other burner. I swapped the wires on the control and it does not appear to be the control. I swapped the wires on the overheat sensor and it does not appear to the sensor. the receptacle looks ok but that is the only item I cannot check. help
misterfixall
#2 Posted : Saturday, January 5, 2008 5:25:34 PM(UTC)
misterfixall
this is not a model # usually # is found where oven drawer meets body of stove ,you will see sticker with model +serial #
ellist
#3 Posted : Sunday, January 6, 2008 5:50:13 AM(UTC)
ellist
The model # is RC8400XBQ0
misterfixall
#4 Posted : Sunday, January 6, 2008 7:02:18 AM(UTC)
misterfixall
cannot locate this model.
