My Fronyt Load Machine Wont Drain Any Water Out I Can Syphone It Out Through The Hose But Wot Drain On Any Cycle It Will Spin Just Wont Drain I Am Thinking Its The Pump The Drain Hose Is Connected To Ut I Am Not Sure How To Test This Theory Or What The Proper Name Would Be To Order The Part Any Help Would Be Appericiated
Remove the tub drain hose from the drain pump and clean it out.It has a filter in there that may be bad, try not to remove the boot from the tub, clamp hard to get back on. If ok, check the pump impeller, sometimes they break. If ok, replace the pump AP4359998
Originally Posted by: richappy  Remove the tub drain hose from the drain pump and clean it out.It has a filter in there that may be bad, try not to remove the boot from the tub, clamp hard to get back on. If ok, check the pump impeller, sometimes they break. If ok, replace the pump AP4359998 would ya believe i took the pump off and tested it and it wouldnt work so i just happened t5o wangt to see how it was made so i took it apart and a dam nail fell out now it works like a charm thanks for your help!!!!
Good job, appreciate the feedback.
