turindoomsayer
#1 Posted : Thursday, July 16, 2009 4:36:50 PM(UTC)
turindoomsayer
My microwave started making a grinding noise and I found that when the turntable is turned off the sound stops. I took apart the turntable and got down to the motor and took all of the pieces and wiped them clean. (there was only a slight bit of dust on them) I examined the turntable shaft and the motor. The turntable shaft seems to be worn on the inside and no longer has a flat spot where it should.
Thank you in advance for your assistance.
-T
magician59
#2 Posted : Thursday, July 16, 2009 7:48:02 PM(UTC)
magician59
Replace it.
turindoomsayer
#3 Posted : Friday, July 17, 2009 7:51:53 AM(UTC)
turindoomsayer
Originally Posted by: magician59 Go to Quoted Post
Replace it.
Thank you for your quick response but I failed to state that the according to appliencepartspros.com, the part is not manufactured anymore. I am needing a substitution of the part with something else. Do you have a suggestion for the "Part Number: AP330091 made by MAYTAG"?
