Yes, the dryer doesnt work no matter where I have the settings.
Sounds like either the timer or the motor.
Is there any way to check to see what one is broke? If its the motor again we will probably just get a new dryer:( but if its the timer we would probably fix it and run it till she dies again. Thanks for you help!!
You can pull the cover off the timer and check for badly burnt contacts.
