krewaj
#1 Posted : Wednesday, July 15, 2009 5:00:01 PM(UTC)
krewaj
Dishwasher signaled code "--" and led above keys blinking normal, push cancel and 2 minute cycle runs out. Replaced 2 micro switches for door sensor. This worked for one run through then went to a loop of restarting it self to a normal cycle. When you press cancel it will stop for 2 minutes than try to cycle again. Then changed circuit board, now it only has normal blinking light above normal and does not run at all.
#2 Posted : Thursday, July 16, 2009 3:29:50 AM(UTC)
Pull the service data sheet behind the kick panel and enter in the pushbutton code for entering diagnostic mode, then hit cancell, should reset computer.
krewaj
#3 Posted : Saturday, July 18, 2009 5:19:31 AM(UTC)
krewaj
Tried and the board doesn't respond to a reset.
help
#4 Posted : Saturday, July 18, 2009 8:02:52 AM(UTC)
You might have a stuck keypad. Might have to change the control panel AP3176986 a bit pricey.Remove the ribbon cable to the control panel and see if the lights still flash, if not, you have a bad keypad in the control panel.
