56BelAir
#1 Posted : Tuesday, June 23, 2009 8:49:35 PM(UTC)
56BelAir
My fridge leaks from the bottom when I fill up a glass of cold water using the door dispenser. I do not notice it leaking when the ice tray fills and I use the automatic ice maker frequently. I only need to fill up a 1/4 to a 1/2 glass of water and I see it leaking from underneath. When I pulled the fridge out I saw no visible cracks on the lines exposed on the back of the fridge. It does not leak from inside the fridge either.
Not sure where to investigate without lifting up the fridge. Anyone know of any schematics out there I can look at? Thoughts?
Paul
Parker, CO
everett
#2 Posted : Wednesday, July 15, 2009 6:38:43 PM(UTC)
everett
We are having the same trouble. The water leak on ours is coming from where the hoses connect into the fridge underneath. There is a blue plastic part with valves that the water tube attaches into. Our tubes were fine on the back of the fridge, but broken at the valve connector. The valve isn't broken on ours, just where the tube connects to it. You probably have the same/similar problem. The next issue is...we haven't figured out how to fix it yet :mad: Still working on it.
