2 Pages12>
4trax250x
#1 Posted : Tuesday, July 14, 2009 5:59:25 PM(UTC)
4trax250x
We have a dryer that within the last year replaced the motor and it has worked like a champ ever since. Today the dryer wont:( I can hear the timer ticking, when I push in the button to start it, it clicks like its supposed to. I took the panel off the back and when you push the button you can hear kind of hum but nothing works. Is this an issue with the termianl fuses that I heard some of you talk about? Or should I check somewhere else for the problem? Any help is greatly appericated!! Thanks.
#2 Posted : Wednesday, July 15, 2009 5:18:53 AM(UTC)
Will the drum turn at all, or is it jammed?
4trax250x
#3 Posted : Wednesday, July 15, 2009 9:39:31 AM(UTC)
4trax250x
The drum doesnt turn at all.
4trax250x
#4 Posted : Wednesday, July 15, 2009 11:17:32 AM(UTC)
4trax250x
I answered that in a hurry and now that I think about it maybe I should clear this up. The drum will turn manually but it will not turn under motor power. When I push the button to turn it on, the switch is what lightly hums not the motor.
#5 Posted : Wednesday, July 15, 2009 11:58:22 AM(UTC)
Sounds like either a bad start winding in the motor, or oil got on the centrifical switch thus burning it out.
If you leave the motor hum, does it heat up and shut down? Pull the dryer apart and see if the motor is seized, or something jamming it.
Here are some parts motor 279827, start switch 3388235 The start switch is almost as expensive as the motor.
4trax250x
#6 Posted: : Wednesday, July 15, 2009 12:11:43 PM(UTC)
4trax250x
The motor isnt what is humming though. THe button you push to start the dryer is what is humming. The motor doesnt make a sound.
4trax250x
#7 Posted : Wednesday, July 15, 2009 4:23:14 PM(UTC)
4trax250x
Anyone else have an idea as to what the problem is??
magician59
#8 Posted: : Wednesday, July 15, 2009 4:54:15 PM(UTC)
magician59
Open the door. Have someone help you by pushing the door switch, simulating a closed door. As you push the start button, have your helper rotate the drum to see if it will begin to tumble. If you are able to do this, replace the motor. Please post your results.
4trax250x
#9 Posted : Wednesday, July 15, 2009 5:33:29 PM(UTC)
4trax250x
No go, do you have any other ideas as to what it could be??
Thanks for all the replies!!
magician59
#10 Posted : Wednesday, July 15, 2009 5:54:39 PM(UTC)
magician59
Does this happen in all the different cycles?
2 Pages12>
