JmJoyce
#1 Posted : Wednesday, July 15, 2009 1:18:40 PM(UTC)
JmJoyce
The timer dial on my Maytag only work on the timed Dry Cycle. Vents clear. Clothes dry perfectly on that cycle but no Intellidry/Airfluff or Perminent Press/Intellidry cycle works. Is it the Timer itself since it does partially work. Or could it be a sensor? Please advise. :confused:
#2 Posted : Wednesday, July 15, 2009 6:57:28 PM(UTC)
Quote:
...no Intellidry/Airfluff or Perminent Press/Intellidry cycle works...
Does it start the cycle?
JmJoyce
#3 Posted : Thursday, July 16, 2009 5:43:05 AM(UTC)
JmJoyce
:confused:
On the regular cylce when I pull up on the knob nothing happens at all. No the cylce doesn't start. Only when I used the timed dry cycle and that works just fine not slow or anything.
#4 Posted : Thursday, July 16, 2009 1:36:09 PM(UTC)
Sounds like the timer has gone bad. If you need the correct part number post the serial number of the dryer.
JmJoyce
#5 Posted : Thursday, July 16, 2009 1:57:16 PM(UTC)
JmJoyce
That is what I thought. #12716496CA is the serial number. Thank you! Janet:D
#6 Posted : Thursday, July 16, 2009 4:04:11 PM(UTC)
Janet,
The timer Part number: AP4042974
