mm6018
#1 Posted : Monday, July 13, 2009 6:42:47 PM(UTC)
mm6018
(Model # 110.66752500) Ever since the dryer was new the high heat didn't seem to work properly. It almost seemed that medium heat was the same if not better. Any sugestions on where to start???
#2 Posted : Tuesday, July 14, 2009 4:02:59 PM(UTC)
Quote:
Any suggestions on where to start???
The complete model number of the dryer.
mm6018
#3 Posted : Tuesday, July 14, 2009 7:49:52 PM(UTC)
mm6018
#4 Posted : Thursday, July 16, 2009 11:21:03 PM(UTC)
Looks like I got blind (one of such days) and did not see the model number. Sorry about it.
Remove the rear panel. Remove the lint chute (#56 on the diagram) and clean it inside. Make sure the blower wheel is clean. Replace the cycling thermostat (#42).
- The cycling thermostat Part number: AP3131939
