nikita
#1 Posted : Monday, July 13, 2009 5:54:44 PM(UTC)
nikita
My dryer does not start when the button is pushed. Obviously i checked the socket...its fine; so is the door/hinge. could it be the (thermal) fuse???? is it easy to get to???
magician59
#2 Posted : Monday, July 13, 2009 7:13:04 PM(UTC)
magician59
Have you tried it in all the dry cycles? If it works in others, the timer is probably the culprit.
nikita
#3 Posted : Monday, July 13, 2009 7:57:43 PM(UTC)
nikita
yes.... nothing. briefly made some clicking sound once under 'low heat'/ after that, nothing. do you think its the thermal fuse??
magician59
#4 Posted : Tuesday, July 14, 2009 6:52:59 PM(UTC)
magician59
That depends on other factors. Try setting the timer to a timed cycle (any amount of minutes). Now just look and listen...does the timer advance? If yes, open the door after a minute or so, and feel if there's heat.
