My dryer quit working. I've traced main power in, power into and out of the selector/timer, and power into and out of the on/off swith. The next component in line is the in-line fuse then the motor, which I can't get to. I was trying to obtain an exploded view of the dryer so I know what to take apart to get to the components I need to check but have been unsuccessful in locating one. Anyone have any ideas?
In order to access the thermal fuse (#7 on the diagram), which most likely is the culprit, you have to remove the rear panel. - The thermal fuse Part number: AP3132867
