DanielH
#1 Posted : Sunday, July 12, 2009 2:59:28 PM(UTC)
DanielH
This dishwasher fills with water but will not wash or drain. All lights on the control panel seem to be working properly. Any help will be greatly appreciated. We have to fix this ourselves by nessesity.
#2 Posted : Monday, July 13, 2009 3:14:54 PM(UTC)
Open the control panel and check the control board for any burned spots.
Remove the toe panel and check for 120 VAC to the motor. Check the motor windings according to the wiring diagram.
Here are the breakdown diagrams and Replacement parts for MAYTAG MDB6100AWQ | AppliancePartsPros.com
DanielH
#3 Posted : Tuesday, July 14, 2009 1:44:39 PM(UTC)
DanielH
Thank you for the tips Gene. The circuit board looks fine. No burned spors or missing solder. As for the motor, can you tell me which wires would carry the 115 volts to it. I have located a harness with the yellow, red, grey and blue wires on it but am not sure which leads to read.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
