I suspect ice maker heater is bad, resistance between test points H & N indicate 8K ohms. From another post indicated resistance should be around 70 - 80 ohms. is the thermostat in series with the heater, anyone out there have access to a schematic?? If I test the continuity between the pins (counting from the far left facing the front of the mold) 1 & 4 shows a low resistance. I am suspicious there is another component between test points H & N and the heater itself. any ideas:confused:???
You probably have bad contacts in the front module, just pull the front off and measure the heater directly. I would order the entire icemaker at this site and make sure you get the factory service part and not a cheap aftermarket.
