cashcraft
#1 Posted : Monday, July 13, 2009 6:50:30 PM(UTC)
cashcraft
My Spacemaker HVM1540 microwave turntable runs when the microwave isn't in use. I noticed this a few days ago. It seems to run all the time. I'm afraid the motor is going to burn out or it will overheat and cause a fire. Its only been in use for a little over a year and isn't heavily used.
I tried unplugging, turning the turntable on/off button to off then on again a few times, running the microwave, and clearing/cancelling. It will stop when the door is opened, but runs once the door is shut. For now I have it unplugged.
Very strange. I tried the GE site but no help. What do you suggest? Thanks in advance.
magician59
#2 Posted : Monday, July 13, 2009 7:17:59 PM(UTC)
magician59
Sounds like either a bad switch or board relay; or a short somewhere in the turntable motor circuit.
GoodThings
#3 Posted : Tuesday, July 14, 2009 3:12:25 AM(UTC)
GoodThings
If your microwave is operating without user interface, check out the national class action lawsuit filed against GE. Go to Home for more information.
