carieira
#1 Posted : Sunday, July 12, 2009 7:22:42 PM(UTC)
carieira
The handle was loose, I opened the panel on the back, fixed the handle.
But now having a hard time putting the door back. The springs are very strong and can't open them and at the same time slide the door in.
Suggestions?
#2 Posted : Monday, July 13, 2009 4:12:03 PM(UTC)
I would try to have someone to help holding the door.
carieira
#3 Posted : Monday, July 13, 2009 6:14:07 PM(UTC)
carieira
Thanks Gene. I did that and it worked.
What Bosh could let us know is that when the door handle is loose we shouldn't unscrew all the screws on the inside part of the door. It this is done the springs get loose and your are in a very DIRE situation.
Unscrew only a few screws and the outside part of the door will be off and then you can work on the loose handle.
#4 Posted : Tuesday, July 14, 2009 4:01:10 PM(UTC)
You are welcome. I'm glad to hear you are back in business.
