Opa
#1 Posted : Sunday, July 12, 2009 11:58:58 AM(UTC)
Opa
In recent days my fridge has been running constantly. I believe that the defrost timer needs to be replaced, and am waiting for the part to arrive.
Once the part is here, and it is replaced , I would like to test the temperature controls. I am not sure if the control is stuck in closed position. Please advise how to test?
Thanks for you time.
woodchuckie
#2 Posted : Sunday, July 12, 2009 2:33:49 PM(UTC)
woodchuckie
How to check here>Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
As you turn it to the warmer setting it should cut everything off and come back on when you turn it colder.
Opa
#3 Posted : Monday, July 13, 2009 10:16:21 AM(UTC)
Opa
Actually, my question is how would I test the temperature control unit outside of the refridgerator. In other words, I would like to test for continuity, by using an ohmmeter. Do I have to cool the unit down first to check if the control interupts the circuit? Thank you for your reply.
woodchuckie
#4 Posted : Monday, July 13, 2009 12:58:50 PM(UTC)
woodchuckie
My previous post has a link which tell how to check it with an ohm meter.
