suniliset
#1 Posted : Friday, January 4, 2008 8:45:04 AM(UTC)
suniliset
Ihave the part 8273525 ,but I dont know how to replace it ,please help!
#2 Posted : Friday, January 4, 2008 4:24:09 PM(UTC)
Remove the door as it's described in the "Use & Care" book (page 25).
Put the door on a flat surface with the door handle facing down. Remove the screw held the front glass on each side of the door (# 18 on the door break down diagram).
Remove all screws held the side and the bottom trims.
Remove the screws held the door handle (#2 on the door break down diagrams).
Assemble in the reversed order.
Good luck.
