airheads
#1 Posted : Sunday, July 12, 2009 12:40:12 PM(UTC)
airheads
Hi I have a Kenmore microwave oven (Part #911.414.85994)that is part of a regular oven/microwave built-in unit (Part #911.41489992). The turntable stopped working and the microwave no longer heats. I can't find a wiring diagram for the unit so I don't know if the turntable motor and heating problem are connected, or if it's the magnetron. Any help would be appreciated.
Thanks,
Larry
#2 Posted : Monday, July 13, 2009 12:35:22 PM(UTC)
Hi Larry,
You have to have a simple multimeter to diagnose the problem.
Remove the microwave from the oven body. Remove the microwave outer case. The tech sheet should be inside.
Check the door switches for continuity with the door closed and opened.
If there is nothing wrong then the problem most likely is a bad control board.
- The door switch Part number: AP2024337
- The microwave control board Part number: AP3202740
This job, especially removing the microwave from the oven cabinet, is not very simple. If you do not feel yourself comfortable, it's better to hire a professional to do it for you.
airheads
#3 Posted : Tuesday, July 14, 2009 8:11:48 AM(UTC)
airheads
Thank you for your help Gene. I have a multimeter and the exploded view of the cabinet so I will give it a shot!
Thanks again,
Larry
