I have replaced the dryer element and the element isn't coming on. What other parts would I need to purchase to make the dryer element come on. thanks smiley
There are two thermostats on the heater-can that will cause this and go bad more often then the heater. You should check them for continuity with an ohmmeter because they are not necessary the problem. Check you vent because poor airflow can cause this the thermostats to go bad. Hope this helps! Clothes Dryer Repair Guide
Originally Posted by: smiley60  I have replaced the dryer element and the element isn't coming on. What other parts would I need to purchase to make the dryer element come on. thanks smiley Also check, and make sure you have full power coming to the dryer. Just because it runs, does not mean you have full power. Tom www.applianceeducator.com:cool:
