kathy ouellette
#1 Posted : 16 years ago
kathy ouellette
I have a Calupso washing machine that will not spin. It gets to the last 6 minutes of the cycle, and begins spinning. It makes an unpleasant noise then stops. This is after I have gotten the error code lp and the machine has been opened and the rinse spin cycle has been selected to finish the wash. Up to this point I have had no problems. Any thoughts?
sidfink43
#2 Posted : 16 years ago
sidfink43
Hi Kathy
Well, you asked for thoughts, here are some.
These are really great machines, but are very difficult to work on. Also, the LP error code does not seem to be in the troubleshooting guide. Noises are also difficult to diagnose because the way we do that is to first listen and try to ascertain the area that is causing the noise, and we cannot do that in your case.
I am going to link you to the service manual for this machine, and suggest you try the troubleshooting and diagnostgic routine to see if you can come up with something. I am also going to suggest that you remove the pump and clear out any debris and check it to see if that is the source of your noise and problem.
Here is your manual
http://adcxns1.whirlpool...4632a4/$FILE/8178010.pdf
Good luck, sorry not to have been of greater help.
Machine won't spin - makes loud noise (Washer Repair)
by lpcon 11 years ago
Washing machine won't spin (Washer Repair)
by Mjbruner1 12 years ago
Washing Machine won't spin out water (Washer Repair)
by dlong55 12 years ago
Washing machine won't spin or drain after rinse cycle (Washer Repair)
by brodyn 12 years ago
frigidaire flse72gcs7 gallery laundry center washing machine won't spin (Washer Repair)
by hyperturtle 12 years ago
by watertoy321 13 years ago
by Monty Wyne 14 years ago
Washing Machine won't spin (Washer Repair)
by golfer63 14 years ago
Washing Machine won't spin only tries (Washer Repair)
by tferguson1970 14 years ago
by neely732 15 years ago
washer machine won't spin (Washer Repair)
by elbebe2525 15 years ago
by telesa 15 years ago
by stevecook 16 years ago
hotpoint washing machine won't spin with clothes (Dishwasher Repair)
by Wayne Thomas 16 years ago
washing machine won't spin the water out it (Washer Repair)
by jgosch 16 years ago
