carl550k
#1 Posted : Thursday, January 3, 2008 8:00:49 AM(UTC)
carl550k
kids overloaded washer last week now it wont drain. it will spin, agitate, and everything else. there was a smell of burnt electricals whenthe washer was first started. has not happened since and works through all cycles. i took front cover off the belt is stilll there and driving the pump. i also removed the hose going to the pump from thr drum? there was no clogs. dont know where to go from here. any ideas? thanx carl
#2 Posted : Thursday, January 3, 2008 6:25:08 PM(UTC)
If the hose is not clogged then the problem could be only the pump.
A smell could come from the belt. It's better to replace it.
- The part number for the pump is AP3873050
- The part number for the belt is AP428043
Good luck.
