bonnie smith
#1 Posted : Friday, July 10, 2009 4:04:51 PM(UTC)
bonnie smith
how to change inlet valvue
sidfink43
#2 Posted : Saturday, July 11, 2009 5:31:20 PM(UTC)
sidfink43
Hi Bonnie
There should be two screws which hold the console to the cabinet at each end of the console (they may be behind a trim part). Unscrew them, and flip the console forward and up. Unhooked the plastic lid switch coupling and use a screw driver to flip out the two brass looking clips.
You can then pull the entire cabinet off the back, exposing the inlet values for a quick and easy change.
Guest (4)
