:confused:
MY WASHER LEAVES WATER IN THE TUB OCCASIONALLY AND SMELLS VERY MOLDY WHAT CAN CAUSE THIS?
Sounds like a partial obstruction in your drain system.
Take off the bottom panel and clean out the drain hoses and pump assembly and you should be fine.
Good luck
