I have trouble with the dryer not starting. This has been going on for about a year. I had a service man out to confirm what i thought the problem was. He also thought the control board.We have tried a few gimmicks and the dryer continued working. Now is the time to fix it. My problem is i don't know how to get to the control module. Do i need to take the back then the top off or what is the procedure. Any help is appreciated
It's a pretty easy job. Take the cover off by removing the screws in the back. Here is the service manual which will guide you through it. https://secured.whirlpoo...ILE/Duet%20Job%20Aid.pdfGood luck, let us know how it turns out, and if a new control board does not fix it post a detailed description of the problem and let's see what else we can come up with.
Thank you for the manual/ I hope i don't have any extra parts when finished.:)
I replaced the control board. It seems to be working better but it is still not right. If i leave power to the dryer on for a while i have to turn off or unplug the dryer then plug it back in and then it will work fine. If the power is left on i can see all the lights on the console board seem to be faintly lit and the dryer will not start until i unplug it. I think we had a lightning strike close by a year ago and that is when it started having problems I now have it plugged in to a surge protector.
Well, sorry that did not fix it.
A lightening strike causes all sorts of problems because of the current that is induced in wiring. A strike near our house last month induced current in the TV cable which fried a DVD player. Go figure!
I would start by thorughtly examining the wiring, and if nothing is found replacing the power cord, not likely a problem but an inexpensive thing to rule out. After that you may be looking at replacing the wiring harness, but that is purely speculative.
Sorry I cannot be more helpful, but lightening and appliances just do not do well together.
Let us know if you find a solution, or need some more ideas.
