Stillwater
#1 Posted : Wednesday, July 8, 2009 7:58:02 PM(UTC)
Stillwater
After a recent thunderstorm, our 16 year old oven is not working. The door is locked, and the display is unresponsive. The cooktop is working, as it should be. I have reset the breaker, and even left it off for several minutes, wih no luck. I have read about the "slow-blow" 20A fuse (AP3110028) in this forum, but since the door remains locked, I was wondering if I should consider purchasing the solenoid assembly (AP4379824), as well. I would certainly appreciate any additional advice anyone may provide.
Thanks!
#2 Posted : Thursday, July 9, 2009 11:45:45 AM(UTC)
Quote:
...I have read about the "slow-blow" 20A fuse (AP3110028) in this forum...
I do not think there is a such fuse in your oven.
Quote:
...the display is unresponsive...
Is it blank or it does not except any inputs?
What is the rest of the model number? You can unlock the door manually from the rear panel.
Stillwater
#3 Posted : Thursday, July 9, 2009 8:17:24 PM(UTC)
Stillwater
I typed in the wrong number for the correct fuse - s/b AP3026588. The complete model number is KERH507YWHO. The display is blank, and it will not respond. Thanks.
#4 Posted : Friday, July 10, 2009 1:52:03 PM(UTC)
According to the Wiring diagram, there are no fuses in this range.
Looks like the control board has gone bad. If you need the correct part number for the control board then post the color of the key panel.
Stillwater
#5 Posted : Tuesday, August 18, 2009 2:03:38 PM(UTC)
Stillwater
Gene, I finally got the control panel in and connected, correctly, but it is still not working. It appears to me that there is no power getting to the panel. The cooktop still works, as it has throughout this debacle.
I am wondering if the door lock solenoid may also be bad, somehow casuing a loss of power to the control panel. With the service panel off, I have manually unlocked the door, only to have it relock, when the stove is plugged back in. I can't think of anything else it could be - unless the part I received from APP is bad...?
Please advise any thoughts.
Thanks,
Frank
kwmontreal
#6 Posted : Sunday, November 7, 2010 4:06:14 AM(UTC)
kwmontreal
I now have the exact same problem. I would like to know how it worked out for you with the door locking mechanism? How do we get the darn thing open??
Thanks.
Kent
KDRP467KSS08 / KDRP467KSS0 KitchenAid oven not working (Oven Repair (including Ranges and Cooktops))
by larrywick 10/18/2019 2:28:40 PM(UTC)
