2 Pages<12
#11 Posted : Thursday, July 9, 2009 3:27:03 PM(UTC)
Based on the result of your test there is nothing wrong with the optics and the problem is a bad ice maker. Just in case I would also check if there is 120 VAC at the wall plug for the ice maker. Check for it between the pins where the black and white wires go. If there is nothing wrong then replace the ice maker.
- The ice maker Part number: AP3182733
comp101
#12 Posted : Thursday, July 9, 2009 4:25:16 PM(UTC)
comp101
THANK YOU!!! I tested the white and black leads with maker still plugged in and voltage was .5ac. Unplugged the maker retest and have 111.00vac. So I will go with what you suggest and go from there. Been a good unit other than the ice maker. Thanks again to Gene for all the help.
#13 Posted : Thursday, July 9, 2009 7:32:19 PM(UTC)
Gene/
2 Pages<12
