miltrot
#1 Posted : Wednesday, July 8, 2009 9:45:07 AM(UTC)
miltrot
how do you replace the thermal fuse.
sidfink43
#2 Posted : Thursday, July 9, 2009 3:51:07 PM(UTC)
sidfink43
Hi Miltrot
On this model you should be able to insert a putty knife between the front panel and the top panel at each end and release clips that hold the top panel on.
You can then remove the front panel, and this will give you access to the blower housing which holds the thermal fuse.
Replacing Thermal Fuse on Whirlpool Accubake (Oven Repair (including Ranges and Cooktops))
by jermainejones 11/20/2016 8:28:24 PM(UTC)
Oven won't heat after replacing thermal fuse (Oven Repair (including Ranges and Cooktops))
by bill cote 11/29/2012 9:30:48 AM(UTC)
problem replacing thermal fuse in wall oven (Oven Repair (including Ranges and Cooktops))
by Tosha1 6/18/2009 11:43:24 AM(UTC)
