There is a ratiling noise in our dryer when starting and running. I took the front service panel off and the lint assembly off. When I ran the dryer the noise seems to be coming from the blower fan. The blower fan is spining freely on the moter shaft. Is this normal? Could this be causing the noise?
Quote:...The blower fan is spining freely on the moter shaft. Is this normal?... No. Quote:Could this be causing the noise? Yes. No doubt about it. The blower wheel Part number: AP4062362
