washer wont fill with water or wash on any cycle but will dump water and spin tryed new timer still doesn't work what is wrong need help right away
The first thing I would do is check if there is water to the washer. If there is nothing wrong then the water valve most likely is the culprit. - The water valve Part number: AP3363282
