Washer go through all cycles but will not spin...water will drain but won't spin
Odds are it is the lid switch. Cost me $79.95 to find out.
I couldn’t find any lid sdwitch to check, so I took the front off. Belt and everything looked GREAT. But I still could not see Any “lid switch”. Water level guage looked ok. So I called GE.
Sevice man came out and said “The lid switch needs resetting”. I said “What lid switch? I don’t see any”. He said “It’s there – It is MAGNETIC”.
He said to reset the switch, UNPLUG the washer for a full minute. Then replug. WAIT. In 10 to 20 sec you will hear a click. When you do, Raise and lower the lid at least FIVE TIMES. The switch will reset.
And he showed me that it worked! No parts needed!!
