flybyfroebe
#1 Posted : 16 years ago
flybyfroebe
I canpush the cycles button and a green light comes on and when i push the options button the green light comes on and it is ready, nothing happens when i push the start button. green lights still stay on but the start button does not do anything. please help:confused:
#2 Posted : 16 years ago
The first thing I would do is check the door switches for continuity.
What is the complete model number of the dishwasher?
flybyfroebe
#3 Posted : 16 years ago
flybyfroebe
the door contacts must be working if the green lights come on pushing the cycle buttons,the only # i have is p/n154444501, hwere is the serial #.thanks
#4 Posted : 16 years ago
You can use the Model Number Locator.
flybyfroebe
#5 Posted : 16 years ago
flybyfroebe
model # fdb956rbc1 serial # th24955726 thanks
flybyfroebe
#6 Posted : 16 years ago
flybyfroebe
for frigidaire dishwasher fdb956rbc1 serial th24955726 new email address is ksfroebe@att.net
#7 Posted : 16 years ago
The Tech sheet and the Parts manual might help you.
flybyfroebe
#8 Posted : 16 years ago
flybyfroebe
thanks for the info,what is the door switchs called in the manual and a way to continuity. If you can let me know if the repair is worth it. I'm willing to pay up to $200 or I can buy a new one for around $500. Thanks again for your help.
#9 Posted : 16 years ago
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter.
If you are going to fix it yourself then it's going to be probably less than $200, but you have to diagnose the problem right.
The door switches are included in the door latch (#12 on the door diagram).
