JELLYGIRL72
#1 Posted : Wednesday, July 8, 2009 7:14:41 AM(UTC)
JELLYGIRL72
the dish washer will fill and drain, heat and everything but the dishes are not being washed. any suggestions:confused:
#2 Posted : Wednesday, July 8, 2009 1:22:49 PM(UTC)
If the motor is running, you probably have a busted chopper assembly.
Remove the upper spray arm tube by twisting it off and take out the torq screws on the upper pump housing and remove. Remove the half round pump cover and remove the chopper assembly. If clogged up or broken, order it on this parts site together with the check valve located in the bottom of the housing.
Chopper AP3039186, check valve AP3175191 You can click on your model # to see how all the parts are assembled.
