Jim Bags
#1 Posted : Monday, July 6, 2009 4:37:15 PM(UTC)
Jim Bags
in any cycle selection, this machine will fill and agitate, but then won't spin or drain or second rinse. Any ideas?
sidfink43
#2 Posted : Wednesday, July 8, 2009 6:57:15 AM(UTC)
sidfink43
Hi Jim
Sounds like a lid switch problem.
Take the two screws out that hold the console to the cabinet and flip it up. Disconnect the plastic coupling leading from the console to the cabinet, and take an insulated wire, ends exposed and insert it into the two outer holes on the connector coming from the console.
Put the machine in spin cycle, and if it spins replace the lid switch.
If this does not solve it, post back with your results.
Good luck
