2 Pages12>
genuine
#1 Posted : Thursday, July 17, 2008 1:59:03 AM(UTC)
genuine
Hi there my problem is that the ice trap door won't open when you try to get ice it falls into door from ice bucket but flap will not open ..... any help would be appreciated :)
#2 Posted : Thursday, July 17, 2008 1:02:25 PM(UTC)
Did you hear a click when depressed the dispenser cradle?
genuine
#3 Posted : Thursday, July 17, 2008 3:25:12 PM(UTC)
genuine
yes there is a click noise but no movement on trap door
#4 Posted : Thursday, July 17, 2008 4:15:28 PM(UTC)
You have to take apart the ice & water dispenser on the freezer door to find out what is wrong with the chute door.
Use a small flat screwdriver to unlock the tabs at the bottom of the control panel. Slide the bottom out and down.
Disconnect the wiring harness connectors.
Remove the four Phillips screws in the door dispenser housing.
Slide out the housing and disconnect the target switch and dispenser light connectors.
Diagnose the problem and find needed parts, using the reference numbers from the break down diagram.
Here are the break down diagrams for the GE refrigerator Model GSS20IEMBWW
genuine
#5 Posted : Friday, July 18, 2008 12:17:08 PM(UTC)
genuine
thanks for your help it turned out to be the solinoid for the trap
mgprokosch
#6 Posted : Monday, March 9, 2009 4:40:50 AM(UTC)
mgprokosch
I had a similar issue. My trap door flap fell off the door arm...
The disassembly directions are accurate, except if you are wanting to remove the electronic panel to get to the 4 screws, you first have to release 2 sping clips in the outside 2 holes by pushing the spring clips up to release thembefore pulling them out from the bottom. I am repaired and operational.
jjansb
#7 Posted : Monday, July 6, 2009 12:46:39 PM(UTC)
jjansb
I replaced the solenoid and it made the problem worse. I used to be able to just flip it from underneath and then it would close now I have to use more force to get it to close???
#8 Posted : Monday, July 6, 2009 12:48:44 PM(UTC)
What was the original problem? Post as many descriptions as possible.
What is the complete model number of the refrigerator?
jjansb
#9 Posted : Monday, July 6, 2009 1:08:26 PM(UTC)
jjansb
It is a GE model GSS201EMBWW
The ice trap door was not shutting so I ordered a new solenoid. I put it in and the problem is worse. I used to be able to just reach underneath and flip the door and it would shut now I have to use more force to get it to shut and do it several times
#10 Posted : Monday, July 6, 2009 1:17:33 PM(UTC)
There is a 5 seconds delay for this door by design. Maybe that's why you can not close it? If this is not the issue then double check how you assembled the parts.
Here are the breakdown diagrams and Replacement parts for GE GSS20IEMBWW | AppliancePartsPros.com
Guest (8)
Ice trap door (Refrigerator & Freezer Repair)
by jjansb 7/6/2009 12:49:13 PM(UTC)
2 Pages12>
