Fembal
#1 Posted : Monday, July 6, 2009 10:58:06 AM(UTC)
Fembal
My gas stove burners are not ignited when I turn the knob on. I hear the clicks but only two of the 5 electrodes spark consistently (sometimes a third one sparks but it's very sporadic).
I'm not sure what the cause is and I would appreciate any help that will point me in the right direction. I'm trying to save a little money like everybody else but will gladly find someone to fix this if it's not simple enuff.
Thanks y'all. UserPostedImage
magician59
#2 Posted : Monday, July 6, 2009 11:14:35 AM(UTC)
magician59
They could be merely dirty. Just lightly brush the electrodes and the flame diffusers with a small wire brush. If this doesn't help, check to make wure the wire leads to the electrodes aren't disconnected.
Fembal
#3 Posted : Monday, July 6, 2009 11:21:18 AM(UTC)
Fembal
Thanks for your response. I've actually already done that & also swapped the electrodes. With the swap, the 2 spots (left hand side) that were working before are still working and the 3 that weren't working before (middle & right burners) are still not. Could it be the spark module?
magician59
#4 Posted : Monday, July 6, 2009 11:28:31 AM(UTC)
magician59
Could be either the spark module, or the individual switches for those burners. There is really no way to tell which, without testing. It may be slightly easier to replace the spark module than the switches, but probably more expensive.
Fembal
#5 Posted : Monday, July 6, 2009 11:32:26 AM(UTC)
Fembal
Thanks "Magician". By the switches, do you mean the knobs for the burners or are these electrical switches in the stove?
Dan O.
#6 Posted : Monday, July 6, 2009 12:36:37 PM(UTC)
Dan O.
Quote:
when I turn the knob on I hear the clicks but only two of the 5 electrodes spark consistently
All the ignition switches do is allow power to flow to the spark module. If you hear it clicking, power is getting there and the switches are not the problem.
If the problem burners are not sparking even though you can hear the spark module clicking and the electrodes at the burners are Ok, there could be a problem in the wiring from the spark module to the burner electrodes or the spark module could be 'weak' with age and require replacing.
LINK > Kenmore 362.73424200 Spark Module (no picture)
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
magician59
#7 Posted : Monday, July 6, 2009 1:00:22 PM(UTC)
magician59
On the inside of the cooktop, stradling each valve, is an electric switch. It is responsible for sending the signal to the spark module to send the current to its respective burner. Since you're hearing a click, chances are you need to replace the spark module.
Fembal
#8 Posted : Monday, July 6, 2009 3:17:02 PM(UTC)
Fembal
Awesome, very useful. Thanks guys. I ordered the spark module & will attempt to replace.
