It takes only 2 days for the cooling coils behind the panel in the freezer to completely frost over. The time for the frosting process has gradually shortened over the recent few months. Frost also appears at the exit door of the ice dispenser inside the freezer. Where to look/what to do? Thanks, Espritman
Is the frost being defrosted by the auto defrost system.
Leaky door gaskets and an ice door flap not shutting all the way will increase frosting.
I don't know if the frost is being defrosted by the auto system or not but it is frosting over SO quickly...
The door gaskets appear to be secure. Is there a foolproof method of testing? Although I can't determine it by looking, the ice maker flap may not be secure because of the quick forming of 'snow' around the inside ice maker opening. A narrow foam strip came out of somewhere. Could the leaky ice maker flap cause the coils to completely frost over within 2 days?
I defrosted the entire refrigerator on Friday. The unit has not stopped running since then. Nearly everything in the frig spoled by tonight (Sunday). Thank you again. Espritman
Thanks, Woodchuckie. I'm on each of your tecommendations. Preventing a $100+ service call and/or worse; replacing the fridge isn't in the cards. I'll reply after the test. Anything else, please let me know. Espritman
