Darbymon
#1 Posted : 17 years ago
Darbymon
I have to check my defrost timer, thermostat, and heater coil. I cant find the timer. I think its in the refridgerator side but I am not sure how to drop unit to see inside
#2 Posted : 17 years ago
It's behind the control panel in the fridg section. It is a pc board called adaptive defrost.
To check this, go to www.applianceaid.com to get info on putting it manually in defrost.
Darbymon
#3 Posted : 17 years ago
Darbymon
I tried to get to the board, I removed the 2 screws behind the box but it wont go anywhere, HELP?
