I am installing a new jen-air under the counter wall over jjw9530 it has different wire than my old GE. It has 4 wires 1 red 1 black 1 red and a bare ground, the wall outlet only has 3 wires 1 red 1 black and a bare. how do I connect the wiring??
Looks like this a Canadian model and I'm not familiar with Canadian codes. Maybe somebody else on the forum can help you better.
Quote:Model Number: JJW9530 Not that it will help with your question but that model number is incomplete. You can find tips for locating the model and serial number identification tag on your appliances at the following link: LINK > Model Number Tag Location GuideQuote:It has 4 wires 1 red 1 black 1 red and a bare ground It should usually have a red, a black and a white... besides the ground. Quote:the wall outlet only has 3 wires 1 red 1 black and a bare. how do I connect the wiring? You probably can't. It sounds like your old power supply provided only a 240 volt circuit. You may need to have an electrical wire a new 120/240 volt circuit to your new oven. Consult with a local electrician. JMO Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
