ckadaja
#1 Posted : Tuesday, January 1, 2008 7:44:44 PM(UTC)
ckadaja
My dryer is about 3 years old. It has become very squeeky with a wet load. Quiter when is get dry. Any Ideas.
Corey
#2 Posted : Wednesday, January 2, 2008 2:42:30 AM(UTC)
Check you bubblegum slides in the front panel, probably worn down, replace them before the plastic rim gets destroyed.
If ok,pull the drum out and check the bearing in the back.
