E Jim K
#1 Posted : Friday, July 3, 2009 7:26:14 AM(UTC)
E Jim K
My Kitchen Aid side by side stopped making ice but cold water continues to flow from the door.
Following the forums here, I have run through the common checks: Switch is "on," and the water inlet tube is not frozen or blocked.
I have found the pump at the back of the unit and learned which one pumped water to the water dispenser and which pumped water to the ice maker. If I switch the plugs (putting the water dispenser plug on the ice maker pump,) I can get the pump to work.
Is my logic correct? Do I simply need to replace the pump?
#2 Posted : Friday, July 3, 2009 7:50:36 AM(UTC)
If the temperature is under 15 degrees in freezer and the water solenoid puts water in the icemaker, you probably have a bad icemaker AP3182733
E Jim K
#3 Posted : Friday, July 3, 2009 8:24:22 AM(UTC)
E Jim K
Thanks Rich...to be clear, right now there is no water going to the ice maker. When I switched the plugs, I was able to get the solenoid to pump water to the ice maker.
Does this still sound like a bad icemaker?
#4 Posted : Saturday, July 4, 2009 2:20:21 AM(UTC)
I am 90% sure you have a bad icemaker. If you have a voltmeter, per the icemaker data sheet tucked under the front kick panel, you should remove the icemaker cover and measure 115 between pins L and H. Your data sheet should confirm these pins as the power pins. Voltage there would confirm a bad icemaker.
Guest (4)
Kitchen Aid Ice Maker stopped working (Refrigerator & Freezer Repair)
by wocao 10/3/2009 8:35:33 AM(UTC)
