i have a 5 burner cooktop. 1 burner clicks and then ignites. the other 4 burners do not click. they will lite, but only if the first one is lit. they do not click but gas does come through. do i need new ignitors and how do i replace them?
Quote:1 burner clicks and then ignites. the other 4 burners do not click. they will lite, but only if the first one is lit. There may be a problem with the ignition switches on the burner valves or in their wiring. All of the switches come together in an assembly along with their wiring (see the following link). LINK > Whirlpool GLT3615LB02 Ignition Switch/Wiring Asm.Quote:do i need new ignitors There are spark electrodes at the burners but if they were defective they should not work when that one burner was turned on either. There is a spark module but only one so it shouldn't be the problem if even one burner worked reliably. That leaves the ignition switches for those 4 burners not powering the spark module either due to their failure of failure of their wiring. JMO Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
