Hi, I have a Samsung RS2630SH. I need to replace the water tank- it's cracked. One hose goes under the fridge and comes out at the front near the freezer door. It looks easy to fix. However, it's impossible to see where the other hose goes. I suspect it goes underneath and to access it, you have to lie the fridge on its back. Is this correct? Thanks in anticipation
