When I turn on any one of the burner controls to "light", the rear, right hand burner clicks and the ignitor sparks. When I turn on the controller for that burner, it sparks and lights. I can light them all manually. But none of the ignitors click or spark.
Thank you in advance to anyone that can help me out with this issue.
Don
I'm afraid that is not the model number of the appliance. You can find tips for locating the model and serial number identification tag on your appliances at the following link: LINK > Model Number Tag Location GuideQuote:When I turn on the controller [the rear, right hand burner], it sparks and lights. But none of the ignitors click or spark. I guess you mean none of the other burners click or spark. If that is the case, there may be a problem in the ignition switches on the burner valves or the wiring from them to the spark module or from the spark module to the burners. Quote:When I turn on any one of the burner controls to "light", the rear, right hand burner clicks and the ignitor sparks. All burners should usually spark together. If any aren't, there may be a problem in the wiring from the spark module to the malfunctioning burner(s). JMO Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
