navagator
#1 Posted : Tuesday, January 1, 2008 2:20:20 PM(UTC)
navagator
Approximately a year or so ago our Amana range's digtal timer lost it's volume. The tone that it produces when a button is pushed or the timer goes off is barely audible. We currently use the microwaves digital timer but it doesn't work as well as the ranges.
Does anyone have any idea what the cause of this problem could be?
Thank you in advance for your help.
Regards,
Doug
#2 Posted : Wednesday, January 2, 2008 11:20:07 AM(UTC)
Hi Doug
In order to provide the most accurate advise I need the complete model number of the range.
navagator
#3 Posted : Wednesday, January 2, 2008 6:08:54 PM(UTC)
navagator
Thank you for your reply.
Here is the model information:
Model # AGS760L
Manufacturer # P1141237N L
Thank you.
Regards,
Doug
#4 Posted : Friday, January 4, 2008 9:16:23 AM(UTC)
Hi Doug,
The audio signal or beep is created by the control board.
In order to fix it the control board has to be replaced.
Unfortunately the part is no longer available.
Regards,
Guest (6)
