mwindsperger
#1 Posted : 16 years ago
mwindsperger
When I start the dishwasher it fills with water and starts washing for a minute and then stops. The lights on the control panel are all still on. A few secounds later it starts washing again then stops. It does this a few times and then totally shuts down, all lights off. :confused: :confused: :confused:
#2 Posted : 16 years ago
What is the complete model number of the dishwasher?
mwindsperger
#3 Posted : 16 years ago
mwindsperger
Hi again, sorry, it is actually an amana sofsound and its model number is ADB12OOAWW (those are zeros)
mwindsperger
#4 Posted : 16 years ago
mwindsperger
Hi again, sorry, its actually an amana sofsound model number ADB1200AWW. Thanks!
#5 Posted : 16 years ago
Sorry for the delay. Remove the toe panel and check the motor and bottom of the pump for any water marks. A slow water leak could damage the motor bearings. Post the results.
Here are the breakdown diagrams and Replacement parts for AMANA ADB1200AWW | AppliancePartsPros.com
mwindsperger
#6 Posted : 16 years ago
mwindsperger
The floor is totally free of water marks.:confused:
#7 Posted : 16 years ago
I'm afraid you did not read it clear.
It says:
Quote:
...check the motor and bottom of the pump...
Need Help Verifing Primary Control Board is bad (Washer Repair)
by davi1td 9 years ago
Bad Primary Switch (B2) (Microwave Repair)
by mvuille 9 years ago
fuse blown on & burnt terminal on primary swithch (Microwave Repair)
by officework13 13 years ago
Transformer Primary Voltage (Microwave Repair)
by Builder99 14 years ago
Kenmore Primary Valve Replacement - Ice Maker Problem (Refrigerator & Freezer Repair)
by shaneb 15 years ago
Mary (Oven Repair (including Ranges and Cooktops))
by mfassy57 16 years ago
mary (Trash Compactor Repair)
by Chrisie4 16 years ago
