on/off switch stuck in "ON "position how do you get facia cover off to release switch or replace it ?
you will need a tourque screw driver .dont know size off hand. remove outside door panel .+control panel. there two side screws also holding control panel on.then you have to remove assembly in side panel held down by clips,which are pushed aside.you can figure out the rest,
p.s assemblng door panel can be a challange for newbies,be patient
Originally Posted by: misterfixall  you will need a tourque screw driver .dont know size off hand. remove outside door panel .+control panel. there two side screws also holding control panel on.then you have to remove assembly in side panel held down by clips,which are pushed aside.you can figure out the rest, tks fr ur help. u mean the 8 torque screws on the inside ssteel panel? Howard Truss
Originally Posted by: Howard Truss  on/off switch stuck in "ON "position how do you get facia cover off to release switch or replace it ? tks fr ur help you meanall the screws on thessteel inside panel? Howard T.
screw size is T20 x 4. just bought the tool today.
